-   -   Bravo cooling (https://www.offshoreonly.com/forums/drives-lower-units/195239-bravo-cooling.html)
Plane Silly 09-12-2008 04:21 PM
Bravo cooling
If you switch to a transom water pickup is it nessessary to still let water flow through the drive. In other words, should you loop the hose and just discharge the water overboard?
Back4More 09-12-2008 05:00 PM
Is the drive not picking up enough water? Why would you switch to a transom mount?
t500hps 09-12-2008 05:08 PM
A buddy has a bravo Top Gun that has transom water pick-ups. Soemone used the drive water pick-ups to discharge water right onto the top of the drives (like a drive shower). We hung over the transom one weekday in calm water at 40mph to see water dumping right on the drive at speed......pretty cool set-up I thought.
Plane Silly 09-14-2008 05:09 PM
I was thinking of doing the drive shower thing but just wanted to know if it was necessary to keep water flowing through the drive.
BenPerfected 09-14-2008 06:01 PM
It is necessary to run water thru Bravos for cooling.
Griff 09-14-2008 07:27 PM
1 Attachment(s)
Here is what I did on my Pantera. It also had a dump out the side of the boat for excess water.
Plane Silly 09-14-2008 08:40 PM
Very cool, thank you!!!
