Drive spacer question
I have a 29 fountain with a 2 inch drive spacer. I want to try the boat without the spacer. What do I need to change back to stock specs? I have the stock studs and o ring and drive fluild but do I need anything else? Thanks for any Help.
NO, nothing else needet.
Just take the downshaft extension off, but you see that once you take the spacer out. Well , i asume its a bravo ?! |
if its a bravo you will need a stock lenght coupler
Originally Posted by ssm-v1
(Post 2700246)
Thanks for all your help, I knew I needed the coupler I just forgot it when I pick up the new studs. So Do you think I will pick up any speed with out losing slip... Thanks
(Post 2700246)
well it depends on wh y the spacer was in there in yhe first place as the x dimesion goes up it loses the leveage to carry the bow high resulting in a flatter running boat you will definatly will loose some high speed stablity but this all depends on again why it had that size spacer in it.also watch the change in water pressure
(Post 2700356)
whats there gear ratio
Sounds like you have a multiple setup issues. If you have a 1.3 ratio you have 27% prop slip. If it is a 1.50 you have 20% slip. A good setup is about 8%. I would dump the spacer and start from scratch with setup. Also consider sending in your prop to be checked and labbed. Call Brett at BBlades. They are the best. 920-295-4435
Originally Posted by procharged 454
(Post 2701054)
I was told by riggs marine that built the enginbe the 2in drive spacer was needed because the lower unit would suck air instead of water. ( drive is to high x dim) I will watch my water pressure but was hoping for more top speed. Most fountain are set up for top speed. BUT with 634 hp on dyno sheet the speed is not there with a 28in left hand prop at 5100 it gone 72mph gps.
Originally Posted by Wahoo ATV
(Post 2701609)
Intiminator prop 71 mph 5200rpm bravo one 28p 70mph 4750 rpm bravo one 28 lab 73 mph 4950 rpm All with 2 inch drive spacer tested with light chop and light load hot 85+ degee day Boat went 71 with stock hp500 Now 577 bulldog with better exhaust and cam. I will start with the drive and yes I need to check into the prop. Season endding need to get moving. |
Your slip is very high and you are using different props, so it is a safe bet the spacer is part of the problem. Try it without one and then try to borrow 1/2" and 1" spacers to test. You are also low on RPM. You should see closer to 5300-5400 with a stock ECM.
Back to basics
What rpm is the engine designed to run at WOT for peak HP????? How far is the propshaft below the bottom with the propshaft parallel to the bottom????? |
post results
Took the hit rod yesterday. Cool day 1 to 2 foot chop and windy day. Now with the drive spacer out and with over 100 gallons of gas.
76.7 at 5400rpm. Beleave it or not the boat came out of the better. The boat had slight chime walk put came out of it and a rooster tail, it never did that before. Maybe with lighter load maybe 1mph or 2 |
1/2" spacer cheap
I have a 1/2" spacer for sale cheap if interested.
Chris |
Originally Posted by diggster69
(Post 2721022)
Chris |
Originally Posted by RunninHotRacing158
(Post 2721031)
diggster69 , P.M. me the details and get it boxed ready to ship :ernaehrung004:
Originally Posted by daredevil
(Post 2721084)
YOYOYO, wait a minute. Does that mean you changed your avatar and now the boat has Bravo's ??? LOL:cool-smiley-027:
(Post 2721098)
We're detuning :cool-smiley-027:
Propably for the dinki ,haha. |
(Post 2721180)
Yaeh,right ! Because your the great detuner ?! LOL
PARTEYYYYYYYYYYYYY !!!!!!!!!!!!!!!!!!!:ernaehrung004:
1 Attachment(s)
(Post 2721334)
I have a 1" spacer and hardware, if interested .
Darren |
| All times are GMT -5. The time now is 07:00 AM. |
