-   -   Bravo XR Service? (https://www.offshoreonly.com/forums/drives-lower-units/203671-bravo-xr-service.html)
Griff 02-26-2009 02:54 PM
Also, there are several things that need to be greased inside the extension box, assuming they are Stellings.
JaayTeee 02-26-2009 05:30 PM
True dat.
front and rear u-joints, slip joint and carrier bearing.
sleek1 02-26-2009 08:06 PM
Originally Posted by CB-BLR (Post 2808866)
So that the teeth wear evenly... They rotate in oposite directions. Swapping sides gives even wear to both sides of the gear faces.
Chris
Thanks Chris, I'll do that next time around.
Chris
GrandLake353 02-27-2009 05:52 PM
I talked to the marina that does all of my service today, and they said that they will not put Amsoil in the drives, for liability reasons. They said that they will only use the Mercruiser Racing Oil. Will it be bad to go from the Amsoil to the Mercruiser Racing Oil?
KAAMA 02-27-2009 11:39 PM
They wont use "Amsoil" for what reason??? Is it because it is Amsoil or is it because they wont use anything other than the Merc Racing Oil???
Griff 02-28-2009 01:51 AM
Probably because they bought Merc HP lube in a 5 gallon bucket at a cost of about $8/quart and going to charge you full retail ($14) quart price.
GrandLake353 02-28-2009 12:21 PM
They claim that since they are a Mercruiser dealer, than the Mercruiser oil is the only thing that they will use. They based this on liability reasons. They also said that they don't know much about the Amsoil. Frankly, if the Merc HP racing oil is good, I really am not dead set on Amsoil, esp. considering that the Amsoil is hard to purchase. I am not a racer, and don't run the boat very hard for long periods of time, so I would be curious to know the differences in the oil, and what the true benefits are with the Amsoil vs. Merc. HP oil? Thanks for the info Griff.
Griff 02-28-2009 02:06 PM
I have always run the Merc HP gear lube with no problems.
Hot Stepper 02-28-2009 02:17 PM
Originally Posted by sleek1 (Post 2806997)
Every 300 hours or 3 years is what my manual says. I just got done doing mine. Everything looked great, but I did have a lot of dried/hard spline grease on the shaft and coupler splines.
I guess someone is making out on my boat as I've had my out drive servied every 2 years or 100ish hours. Should I follow your owners manual suggested service interval................Nah I might even do it more often. Preventive maintenance does have a meaning after all, like it or not.
sleek1 02-28-2009 09:16 PM
I'm just passing on what the Maintenance Schedule states in the owners manual I have. It's not my opinion, assumption, or inclination... just the facts as printed in black and white. I believe that would be preventive maintenance according to Mercury. I'm not telling anyone what to do, just supplying information. You're the captain do what you will with your boat. Heck, change it every six months if you want that's even better.:rolleyes:
