-   -   How do I get the Drive ram pin out? (https://www.offshoreonly.com/forums/drives-lower-units/204549-how-do-i-get-drive-ram-pin-out.html)
Ghostrider 03-09-2009 03:10 PM
1 Attachment(s)
I have no idea what it's correct name is, but I need to get the big rod at the end of the drive where the hyd rams bolt to, out.
It is well and truely stuck in there, and it looks like it isn't supposed to come out. Problem I have is that it's the older model Bravo 1 drive with the non adjustable trim ram end limit so there is no oval hole, just the rod in a round hole that is well and truely stuck.
I have tried a hammer. Now the threads are damaged, but they were stripped anyway so any other ideas would be helpful. Is there something else I need to remove first??
I have the drive off the boat, I just need to replace the front pin / rod thing.
Any help is always appreciated.
DareDevil 03-09-2009 03:20 PM
Heat the aluminum up ,,,but easy and just hammer it out,,,looks like it is seezed in ther pretty good .:eek:
While u heat it take some big pliers and turn it to break it lose !!
Comanche3Six 03-09-2009 05:06 PM
Cut the treaded part off flush with the bar stock. Get a good size Bosch Hammer, use a blunt end bit and buzz it out.
Oh yes, it's true!
diggster69 03-09-2009 11:02 PM
Lay the drive on its side and spray PB Blaster on it then again in a couple of hours it should tap out.
Griff 03-10-2009 12:57 AM
Looks like it seized from dissimilar metal corrosion. Try all of the above. Maybe an air hammer as well.
Ghostrider 03-10-2009 07:47 AM
Thanks lads, I'll give all of it a go and let you know.
I've got a replacement pin so I don't care how this one winds up! I'm going to replace the other end while I'm at it as well, but apparently it has circlips on it so I'll pull them off first before I lay into it with a mallet!
By the way, I'm going to wreck the paint job, what's the best paint to use to re-spray the drive? What primer do I use as well?
Thanks again, you lot are life savers!!:drink:
Cheers,
John
spazboz 03-10-2009 09:44 AM
I've had anchor pins stuck like that before, they are not fun to get out. Heat it up, lube it, beat the piss out of it. It's the only way I know!
OL40SVX 03-10-2009 12:00 PM
Instead of pushing the pin out why not try pulling the pin through the housing...put a bunch of spacers on the other side and tighten an exisitng nut down on the spacers...
even if you are trying to smack it out..this preload will help you lossen the pin...
spazboz 03-10-2009 01:20 PM
Another thing I've found works is getting a pipe wrench or good vise- grip on it and try twisting it loose. No matter what you do at this point, you will most likely end up hurting the pin to get it out.
handfulz28 03-10-2009 02:18 PM
Are these supposed to be difficult to get out? When I tried to install a tie bar, I had a b!tch of a time getting the rams off and trying to move the pin. Then once I got that far, I realized I had the wrong hats....
