TRS Bellhousing studs
Anyone know the correct diameter/thread pitch for the studs the mount the drive to the bellhousing? My steering plates mount over these, so I need longer ones than stock. About 1/2 inch longer. Tried latham, no luck.
The threads that screw into the bell housing are 1/2"-13 NC and the threads which are used for the nuts that hold the drive on are 1/2"-20 NF.Total length of the stud is 3 1/2" with 1 3/8" of unthreaded area in the center.
Originally Posted by MILD THUNDER
(Post 2827415)
Just call and tell them length diameter and thread sizes. Also how much non threadet erea in the center and they match it up ,,,plus there studs are even stronger .:ernaehrung004: |
Marine Machine should also have them if ARP can't help.
ARP has them for shure !!!!
| All times are GMT -5. The time now is 09:20 AM. |
