-   -   Which outdrive gears to go with? (https://www.offshoreonly.com/forums/drives-lower-units/205760-outdrive-gears-go.html)
Eclipse232 03-28-2009 08:33 PM
Hey guys I just bought an 1989 wellcraft eclipse 232. It came with a 350 that didnt run so I just bought a 1996 454 magnum for it. Now i have the outdrive to worry about. Right now i have the option of buying a bravo 1 outdrive with a 1.36 gear ratio or buying a bravo 1 outdrive with a 1.5 gear ratio. I am really confused on which drive to go with...both are relatively the same price, i just have no clue which one to go with. I dont really understand how the gear ratios differ and what the the pros and cons of each gear ratio are.
You guys have any ideas? Thank you for any help,
Chuck
DMOORE 03-28-2009 09:10 PM
1:36 is a lot of gear for a stock 454. It "could" work if you have a small enough prop for it, but...... the ideal setup would be a 1:50 with the correct prop.
Darrell.
Boat Tech 03-28-2009 09:37 PM
Darrell.
x2 on the 1: 50 that would have been more of a standerd set up if from new.
Griff 03-29-2009 01:29 AM
Definately the 1.50. You'll probably still only turn a 23" prop.
Vinny P 03-29-2009 03:26 AM
I agree. A 1.36 gear should only be used if you run out of available props for a 1.50.
Eclipse232 03-29-2009 12:58 PM
Gotcha. Thank you guys!
Eclipse232 03-29-2009 01:06 PM
Then that leaves the prop. Do you guys know what pitch i shoud go with? 23 pitch or a 21 pitch 3 blade?
Griff 03-30-2009 02:01 AM
I'm about 90% sure you'll need a 23" Mirage Plus. If you want better cruise and holeshot go with a 22 Bravo 4 blade and loose 2 mph on the top end.
Eclipse232 03-30-2009 06:56 AM
Thank You Guys Very Much!
MarkDonzi 03-31-2009 04:37 PM
I have a 23 pitch mirage prop if you are interested.
