Originally Posted by RBeyer
(Post 2849605)
How heavy is the boat? I am two years at over 700 HP and 727 TQ with no problems or signs of wear. they are HT's and i only weigh 4200lb dry. The weight may be a contributing factor.
12000 dry. |
Your prob running a 24p 4 blade? What speed?
Thats allot of stress on just 2 drives in that boat, Do they still make them with 2 bravos? Did the upper gear break or started wearing making metal? Yours is a 1.30, I would think the 1.50 would help on the TQ multiples,I seem to remember Dean saying the 1.50 was weaker,Id ask him to make sure. Did the shorties help? boats 12k gas 1700 aroundabout gear/beer 2-300 girls 110,one guy 180 14k mim-15k loaded? wet Generaly the sticking in gear slow/hard to go into gear is the shift ring on the gears [bronze looking]if not installed at a angle, worn flat, the ring is higher on one end making a ramp, the shift fork engages it take the clutch/gear and the ramp throws it up or down,making it ingage the clutch.Also the set up/staked height of the gear package being to short or long will affect the shifting, I hope I said this right:eek::drink: Rob |
Originally Posted by Strip Poker 388
(Post 2849627)
Originally Posted by endeavor1
(Post 2849977)
Wow, right on the money for prop size. 70-72 WOT and from all the figures i have done, you are about spot on for weight also. The reason for the sbd gear set was that the clutch was welded into the gear. RnRed that gear set and problems seem to have disappeared. Then this little deal happened. Maybe its just working out the kinks before we get to far into summer. Just never had these problems with bravos and XRs but they were behind fountains and 500hp power.
The end of last season I blew an HT upper that had about 125 hrs on it with 830 hp/tq in my 36' Apache (10,500 lbs dry). The gear blew a few teeth and split the upper case in half. :eek: Cost me about $6K for the upper. :( Season before that with 100 hrs since new I broke a vertical shaft coupler due to the lower vertical shaft bearing being worn. Dean fixed it and thew in new lower gearsets under warranty, even though I was a few months out of warranty, with no questions asked because I told him a few months earlier the one drive had some metal on the magnet. I've learned that up-keep and maintenance on these drives are imperative and I'm now replacing all the bearings in the upper/lower every year. How many hours on the drives? It sounds like they might be a little tired and in need of a re-fresh. Overall I'm much happier with the BMax than I was with the IMCO Bravo's, which decided to check out within 20 hours... :mad::drink: |
Dang All This Talk About These Makes Me Scared To Use Them On My Fountain.
Originally Posted by johnnyboatman
(Post 2850195)
(Post 2849609)
12000 dry.
(Post 2850195)
(Post 2850195)
I'm not a big fan of IMCO due to the way they treated me when I had problems but what's the feedback on this SCX drive?
I looks like they took the same idea (bigger gears) as the BMax , took it one step further with the lower unit and built their own version. |
| All times are GMT -5. The time now is 04:42 PM. |
