drive wont go up
my bravo 1 drive will only go up if i use the trailer switch , checked the switch and jumped it out still nothing i do have 12 volts @the switch
Originally Posted by chadman99
(Post 2852749)
The trim limit sender on the drive is probably bad or the wires are cracked.
Originally Posted by RBeyer
(Post 2852864)
You need to replace the up relay. I'm not sure of the wire colors but there are two one for up one for down.
I believe you can switch the up and down relays, just to rule this out before buying one, if you switch them, and the problem reverses(now the down doesnt work) then it is a relay, if not most likely the sender or wiring.
If it goes up with the trailer switch, It's not the relay, It's something in the trim limit switch, like griff said.
larry |
