-   -   1991 Bravo One clutch replacement? (https://www.offshoreonly.com/forums/drives-lower-units/208069-1991-bravo-one-clutch-replacement.html)
NOMO 05-02-2009 10:38 PM
Can you buy just the clutch or will I have to get the whole geer set? I was told today my clutch will need to be replaced soon and I will need the whole geer set rather than just a clutch.
Griff 05-03-2009 01:20 AM
You can only buy it new as part of entire gear set.
Mr Gadgets 05-03-2009 08:23 AM
Nomo,
the 91 has the thin floored gears, those parts are no longer available from Merc. They have an upgrade kit with new gears and cone clutch and all the parts in the upper to replace what you have. That is the reason for the answer from your mechanic.
If you can find a good used cone and the gears are not damaged where the cone seats.. that will get you by..
Hope this helps
Dick
jennys express 05-03-2009 11:29 PM
i have a new set of older gears never run but no clutch cone i think there 1.5s i pull a bearing out of the middle of gear it had a dent in bearing it can be relaced
Harvey 05-05-2009 10:25 AM
I think I have the hole upper gear set for a 1993 Bravo 1. If that will work I'll dig it out. I may have a upper set also with a chipped tooth in the gear but a good clutch.
Harvey
252-339-4560
Doller Offshore 05-06-2009 08:21 AM
Call us at Doller Offshore we have a few used old style clutches in stock 954-237-0332 Julio
