-   -   BravoOne or BravoThree? Which is better for Cigarette 35 Hull? (https://www.offshoreonly.com/forums/drives-lower-units/210491-bravoone-bravothree-better-cigarette-35-hull.html)
Gimbo007 06-08-2009 03:12 AM
My boat is a 1996 Iguana 35', builded by Nautirama boat builder in Viareggio (Italy) an designed by Paolo Caliari, basing it on 35ft Cigarette Café Racer's hull designed by Don Aronow.
I'm going to repower the boat with twin Mercruiser 496 Mag HO (425hp) and I don't know what drive to use, BravoOne or BravoThree.
Actually the engines are twin diesel Mercruiser D7.3L (270hp) equipped with BravoThree 1,81:1 drives, having top speed at 38 knots and cruising speed at 30 knots, using 28pitch prop. The boat weight is 4300kg with this engines.
Now I've to choose which drive to use with 330hp-plus and different power&torque curve.
I prefer to have a lower minimum planing speed than an higher top speed for better ride on rough waters and a better consumption at cruising speed, so I think a Bravo III it coud be better for me, but everybody says to me Bravo I is the best for a deep vee 24° hull.
Anyone wants to help me in this choice?
hoozeyurdaddy 06-08-2009 08:43 AM
with what you are doing I would go with the bravo 3's, there better at getting large mass boats out of the water and have great low and mid speed drivability.
Gimbo007 06-08-2009 12:18 PM
Thank you hoozeyurdaddy, I think also that top speed loss would be about 4/5 knots between Bravo Three 1,81:1 and Bravo One 1,65:1.
In the first option (B3) I think my top speed could be 47/48 kn, in the second it could be close to 52 knots.
seafordguy 06-08-2009 12:40 PM
There are a lot of people around that know A LOT more than me, but that is a lot of weight in front of a B3..... (if your build ends up weighing anywhere near what my Cafe does)
US1 Fountain 06-08-2009 04:03 PM
Tons of large cruisers use B3's.
Gimbo007 06-08-2009 04:04 PM
Seafordguy, could you tell me how much does your boat weight and how fast is it?
Bravo III should be better with boats weighting a lot like my Iguana 35' (3900kg dry with twin 496 HO). Or not?
Gimbo007 06-08-2009 04:07 PM
I agree with you, US1 Fountain, Bravo III should be better with boats weighting a lot.
seafordguy 06-09-2009 08:33 AM
I believe a stock Cafe Racer weighs about 9600 Pounds.
I have a little under 600hp from Blown 502's (estimated) and run in the low-mid 70 MPH. (72-73) with 4 Blade Bravo 4 Propellers.
I guess Fountain is right - lots of cruisers do have B3 (which is obviously lots of weight), I guess I just always think of them as the weaker drive when comparing the B1 and B3
Gimbo007 06-09-2009 01:26 PM
Why do you think Bravo3 is weaker than Bravo1?
Consider that my top speed will be close to 56/58 mph, not 70.
DMOORE 06-09-2009 07:38 PM
I'll also vote for the B3. The boat will plane faster, hand have an efficient cruise speed.
Darrell.
Gimbo007 06-10-2009 02:21 AM
Thank you, Darrell, an efficient cruising speed is my performance goal, because 90% of time I cruise at 30/35 knots and I would like to have my best efficiency in this range.
About my top speed, listening to MercuryPropSelector, it should be 57mph at full load (1500lbs people and gear, 200 gallons fuel) , and 64mph at minimum load (500lbs + 25 gal).
hoozeyurdaddy 06-10-2009 09:51 AM
as long as the top speed is around the 65ish, B3 is the best choice, above 65 the bullet will cause the rear prop to blowout and loose all efficiency, but it will give the best hole shot and cruise as stated.
Gimbo007 06-11-2009 02:32 AM
Maybe the New Bravo Three 4 blades front prop could be better for high speed efficiency, always remaining the best choice for medium range cruise.
Gimbo007 06-15-2009 05:11 AM
Someone told me BravoThree's have overheating problems at high speeds.
Is it true?
Maybe I could use drive's shower to solve this problem.
Gimbo007 08-28-2009 05:31 AM
http://www.offshoreonly.com/forums/g...ml#post2941408
Gimbo007 09-14-2009 10:33 AM
After 28pitch props (going 56mph @4300) I tested a new set of 26pitch props, with good results:
The hole shot is better, with less effort for the engines, and at same cruise speed the fuel consumption is 5% less.
Not remarkable changes about top speed, always 57/58 mph at 300rpm plus (4700rpm).
I'm going to test also a set of 24 pitch prop but I don't if Standard, Cupped or Four Blade Front Prop.
What do you think about?
