-   -   TRS and Velvet Drive Problems (https://www.offshoreonly.com/forums/drives-lower-units/210575-trs-velvet-drive-problems.html)
OhioRiverCigarett 06-08-2009 08:00 PM
My starboard transmission are not engaging. What is the first things to check. Are there any good articles on how the Velvet Drive transmissions work? Are they a single speed automation transmission.
DareDevil 06-08-2009 08:18 PM
Is the oil dark and smells ?? i think u burned up the clutchplates.
OhioRiverCigarett 06-08-2009 08:25 PM
How does the shifter work
How does the shifter work?
picklenjim 06-08-2009 08:30 PM
Yes it is a single speed transmission.When you shift to forward fluid is directed to apply pressure to the forward clutch pack.
OhioRiverCigarett 06-08-2009 08:36 PM
Shifter Function
Is the shifter the lever on the rear of the transmission? How do you assure that it is in forward, reverse, or neutral?
c_deezy 06-08-2009 08:40 PM
Have somebody work the shifters and then you watch the other side that is working.
picklenjim 06-08-2009 08:41 PM
Have someone shift it while you stand back there and watch.
redcorvetteman3 06-08-2009 09:00 PM
The bell crank has a ball and spring plunger that detents into the triangle shape plate on the left side. Your cable could be broke or miss alinged. Does it have reverse?
tms1155 06-09-2009 12:54 AM
Could also be a broken damper plate on flywheel or blown drive.
c_deezy 06-09-2009 01:07 AM
Here are a few pics. Shifter from helm is the red piece. Pay no attention to the red-arrows, those were for something else.
http://i116.photobucket.com/albums/o...G_0002_mod.jpg
http://i116.photobucket.com/albums/o...G_0001_mod.jpg
TOASTY 06-09-2009 07:40 AM
I have a take out trans for trs if you need it! its always good to have spares
$650 plus shipping from NJ
[email protected]
215-510-8007
Audiofn 06-09-2009 09:28 AM
Does the unit go into reverse? If it does that wil more or less negate an issue with the shifter and point you at the clutch packs being bad. Is this a new boat for you, or just a problem that just started? Did it ever slip in the past?
cigrocket 06-09-2009 09:46 AM
I have a 71C that needs to be rebuilt, but it was a 925 Huber Built Tranny. If you are interested in a spare or something, send me a PM. Excellent exterior condition, looks new. Good Luck. It was from my old Cigarette Mistress
