Makes sense now !!! SORRY
Just don't over trim a boat ,,,they are ment to run @ level ,,maybe +2-3 not more. If u need to trim a boat higher then that ,,,dial it in corectly and get props that wok. Just my 2 cents. If u wnat a rooster tail ,,,buy a race boat with SSM drives. Later:evilb: |
Originally Posted by DareDevil
(Post 2900098)
Well now I'm back to feeling like an idiot about this whole thing
Originally Posted by jetheadracer
(Post 2900207)
Did you pull the drive yet? should only take 10-20 minutes depending if you have hyd. steering to disconnect. You will instantly know what happened. You should check your trim limits switch. (one switch on each side of your hinge pins, unless it is a HD gimbal) One switch is for a guage/indicator and the other is the limit switch. To adjust them you lossen the two screws. You want to adjust it so it only trims up to you your know max trim height. This will stop you from ever over trimming. To go higher you would need to use your trailer switch. |
| All times are GMT -5. The time now is 11:04 AM. |
