-   -   trs (https://www.offshoreonly.com/forums/drives-lower-units/213105-trs.html)
[email protected] 07-16-2009 11:14 AM
trs
anybody know this ? why is it when im flushing my starbord engine my prop spins, when i flush my port engine it does not.
IS THAT A PROBLEM.
Westcoast 07-16-2009 11:45 AM
what transmission?
[email protected] 07-16-2009 01:24 PM
velvet drive, borg warner
picklenjim 07-16-2009 09:12 PM
Could be adjustment of the shift linkage different between the 2.May just be the clutch plates are a little tighter in the one.Probably doesn't do it in the water. I wouldn't worry about it though.Mine tries to spin a little when I run it on the trailer.
crapr6 07-16-2009 10:20 PM
My BW trans with a TRS will also slightly turn the prop when in neutral and flushing the engine with it on the trailer. Like stated could just be a tight clutch pack.
erik
Mbam 07-17-2009 05:58 AM
If it is a stock un-modified transmission it is usually that the forward clutch plates are starting to warp.
[email protected] 07-17-2009 11:11 AM
thank you!
