-   -   TRS Manuals (https://www.offshoreonly.com/forums/drives-lower-units/213135-trs-manuals.html)
OhioRiverCigarett 07-16-2009 09:51 PM
TRS Manuals
Anyone have a link to online TRS manuals? I am fighting a slipping/ no drive issues and would like to download a service manual.
crapr6 07-16-2009 10:18 PM
I got a factory Mercruiser sterndrive (trs) manual from ebay. Try ebay or google it.
Oh yeah a TRS will not "slip" since it is a direct drive..If there is a slip condtion most likely the trans.
Good luck.
Erik
picklenjim 07-17-2009 06:03 PM
If your having a slipping problem it's either a tranny problem or a spun prop hub if you are running rubber hub props.The TRS drive either turns or it don't.I have the Mercury TRS Service Manual #5 and it does not cover the transmissions.You need to know if you have the Merc Trans ll or the Borg-Warner Velvet Drive trans for the correct manual.
J-Bonz 07-18-2009 12:16 PM
PM me your email addres....
