-   -   need an alpha ss (https://www.offshoreonly.com/forums/drives-lower-units/214262-need-alpha-ss.html)
smallblockford 08-04-2009 01:53 PM
need an alpha ss
anyone see any alpha ss stuf around complete or parts I have seen just a lower but am in need of the upper housing and a drive shaft.
I know the bravo is better but i have a little 16 donzi with a built 355 roller moter and want to go with this setup
anyone knows let me know
thanx
Biggus 08-04-2009 04:04 PM
I have an Alpha SS lower gear case (case only, in fine shape) $500.
Kurt
RSCHAP1 09-03-2009 06:54 AM
I am supposed to pick up an upper this evening:)
540phil 09-03-2009 07:17 PM
I have 2 Alpha ss complete 1 gen II and a stern jack but need help setting it up. I could use some help.
wtfo 09-03-2009 10:17 PM
sent you a pm. what are you needing help with?
540phil 02-19-2021 12:18 PM
Kurt
Search happen to turn up your old post. Do you still have the alpha ss Lower case? I will Buy !!
SB 02-19-2021 12:30 PM
I believe I still have the stern jack instructions in .pdf . Send me your e-mail address and I’ll send’m to you.
SB 02-19-2021 02:18 PM
1 Attachment(s)
See if the upload worked to this thread. Should be Alpha Stern Jack installations in .pdf format
540phil 02-19-2021 02:27 PM
Thank you for the prompt reply SB !
