-   -   Imco extreme advantage (https://www.offshoreonly.com/forums/drives-lower-units/214523-imco-extreme-advantage.html)
fastlane40 08-07-2009 02:57 PM
Does an Imco Extreme Advantage 1998 year drive have straight cut XR gears or spiral Bravo 1 type gears?
How does it compare for strength over a standard XR?
DareDevil 08-08-2009 09:36 PM
The IMCO gears are straight cut and a little bigger aswell as the clutch and bearings.
indywhsle 08-08-2009 10:14 PM
I will let you know about the strength. I blew one of my bravo 1 uppers and got the old style imco. I am running over 700hp per so we will see:evilb:
fastlane40 08-08-2009 10:35 PM
It would be strange if they used the Bravo 1 gears but maybe the XR wasn't out yet.
jlowe 08-09-2009 10:24 AM
I believe they are Bravo style gears with thickened floors like the x drives have.
Mr Gadgets 08-09-2009 08:41 PM
In 98, I dont believe the thick floored gears or the XR gears were out yet. It is possible it has the Imco modified thin floor gears.. They welded the floor and bead blasted and reheat treated them.. The X gears are a better gear, but they all have the same helical cut teeth..
Correct me if I am wrong, but I think all the X stuff came out in 2000?
articfriends 08-10-2009 12:47 AM
Im not exactly sure when the x stuff came out (I want to say 2001) but I can tell you that as Dick says,a 1998 imco is going to have the old thin floored gears that are maybe welded up then then ground back down as that was the best you could get in the 90's in a bravo,Smitty
fastlane40 08-10-2009 07:11 AM
Hi Dick.Lowers are going just great.Next race 5 weeks away.So the 98 Imco isn't going to be a real strong upper thats comparable to an XR?Thanks for your reply Smitty.
JasonSmith 08-10-2009 08:51 AM
I have the IMCO extreme's with the ibeam cases. They break. Just XR gears. I'm sure they are newer than what you are looking at.
I think the problem is with the gears in general. Personally, I think the material is not the best & no matter how strong the case, the gear is the problem.
Someone needs to build a "real" gear with "real" materials.
fastlane40 08-10-2009 03:02 PM
According to the experts the later XR gears are much weaker than they use to be.Easy up and real easy down isn't working.I just recently tore a tooth that destroyed a new upper unit.
Dick who posted previously feels the new IMCO scx is the way to go.Just hard to get around the initial $.
Thats the way i'm headed though.
