-   -   Bravo 1 up grade (https://www.offshoreonly.com/forums/drives-lower-units/216729-bravo-1-up-grade.html)
Goin Nuts 09-13-2009 07:12 AM
Bravo 1 up grade
I broke 2 prop shafts this year and over course lost 2 props . would like to up grade without breaking the bank. I was told to replace the lowers with xrs just wondering if I should replace the whole drive with the xr drive or just the lower would work . The uppers have fine up to now thanks for any help Mark
t500hps 09-13-2009 07:25 AM
Sounds like you have hit underwater objects or someone is putting the lowers together wrong. Some buddies lost shaft/props on 2 different boats. Switched mechanics and never had another problem. IMO, the uppers usually fail first unless one of those senarios occurs.
Goin Nuts 09-13-2009 08:28 AM
I think it just age & hrs the last one I broke when I came out of the water and didn't get the trottles in time driver error
