-   -   Bravo XZ or XR??? (https://www.offshoreonly.com/forums/drives-lower-units/216851-bravo-xz-xr.html)
SonicBunny 09-14-2009 09:21 PM
Bravo XZ or XR???
We are in the middle of a drive build and need to know what will handle a 9k boat with twin 575sci's. We are torn with both but long term is what we are looking for... ideas???
us1kw 09-14-2009 10:15 PM
xr is stronger. XZ was the first answer with hardened gears but not straight cut gears like the xr.
Griff 09-15-2009 02:23 AM
As long as the XZ's can handle the HP, which they should be able to just fine, they will last longer. XR gears tend to wear out faster, but are needed for bigger HP.
BDMarine 09-16-2009 04:33 PM
With that application definitely the XR.
SonicBunny 09-16-2009 07:45 PM
Well, have 8 hrs on a new set of xr's with pinion gear failure... not having the warm fuzzy feeling... lol
BTW, they were cryo'd too.... one drive gear was pitted, the primary's were fine.... both drives had same problems... merc is covering them but not sure if we want to tear down every 8 hrs...
GO4BROKE 09-16-2009 08:04 PM
I kind of wonder about the cryo. I've seen stock bravos last that long with more hp. Pitting is more a manufacturing issue than "usage" issue.
SonicBunny 09-17-2009 05:00 AM
right... thats what my husband thought... he's a mechanical engineer and is actually disecting one of them to have a metalurgy test done.. he has a few guys he works with that can do this... he thinks that they had a bad heat treat run...
LAKESIDE RESTORATIONS 09-17-2009 07:53 AM
How about using the new Imco SCX set up? It will work with the Bravo Transom assemblies, you just need to swap out the helmet. They are rated for quite a bit more than what your 575's should throw at them.. If they may interest you feel free to contact me.. :) Jamie / Lakeside Restorations
JaayTeee 09-17-2009 09:20 AM
Sounds vaguely familliar to what I had happen a couple
of years ago , although one of my driven gears
started to chunk out too. ( they were a brand new set also)
If and when mine crap out again, I think I'm
going to try the helical type ( X/XZ)
laszlo01 09-22-2009 10:46 AM
Any experience with the Billet marine XR uppers with there Imco billet lowers ? This is our solution for our build this winter and wondering about others experience with them.
