-   -   What Gear lube are you running in your TRS (https://www.offshoreonly.com/forums/drives-lower-units/217423-what-gear-lube-you-running-your-trs.html)
502ss 09-24-2009 05:08 AM
Whats the best Gear lube to run in a TRS?
Thanks! :drink:
Rookie 09-24-2009 06:05 PM
I've been running Royal Purple for about 6 years.
07DominatorSS 09-24-2009 07:39 PM
Read this, and I bet you'll reconsider using it.
http://www.amsoil.com/products/gearl...hitePaper.aspx
For another company to put someone's name on tests, they better be right, otherwise they'll be facing some serious consequences.
502ss 09-24-2009 08:59 PM
Read the whole report and with no big surprise Amsoil came out as the best choice but I really liked the Penzoil Synthetic number also. I guess maybe one of those two!
Great Article! Thanks! :drink:
502ss 09-24-2009 09:01 PM
If you have had good luck with your royal purple for six years then dont read the report. After reading it you may have a different outlook on what is the best gear lube!
Biggus 09-25-2009 05:34 AM
-Been running Royal Purple in my Konrad drives for the last six seasons. Just pulled the top caps, zero wear on the upper gears.
smdude 09-25-2009 08:34 AM
Mercury High Performance gear lube!
picklenjim 09-25-2009 03:21 PM
Second that. Why mess with all the other brands when you know this one is right.
502ss 02-06-2010 10:11 PM
I am going to go with the royal purple gear lube. It is called Max-gear correct? Which weight should I run and anyone know the capacity for a TRS drive?
picklenjim 02-06-2010 11:26 PM
TRS drive and reservoir together hold 4 Qts.
