-   -   Transom Drive Adapter Plate (https://www.offshoreonly.com/forums/drives-lower-units/218181-transom-drive-adapter-plate.html)
picklenjim 10-07-2009 01:32 PM
A few months back someone on here showed a adapter plate that covered the hole in the transom from a volvo and was drilled and cut to use a bravo drive.It even had a link to one for sale on ebay.Does anyone remember this or have any links or info on these plates?
tony davis 10-07-2009 01:40 PM
It's a Mercruiser part, available from your local dealer.
Wally 10-07-2009 03:39 PM
i believe this was the posting your looking for:
http://www.offshoreonly.com/forums/s...-500-00-a.html
picklenjim 10-07-2009 04:54 PM
Thanks for the replies guys! That's what I was looking for.:ernaehrung004:
jeffswav 10-07-2009 05:16 PM
I am thinking about raising my Bravo Drive up 3.5 or 4". Anyone know of a adaptor plate for somthing like that. I have a friend with a welding shop that could make one if I knew I could make it work.
crapr6 10-08-2009 11:08 AM
Here u go.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
jeffswav 10-08-2009 05:17 PM
Originally Posted by crapr6 (Post 2969079)
Yes, I saw that. But you need some measurments off of it to determine how high it could be raised. I would like to raise it 3.5 to 4". I would think you would need about 1" of surface area to get a good seal. Depending on how Baja cut the original hole would also have a variable. I talked to my friend last night, he said he could make somthing similar out of steel and have it powercoated.
