-   -   question for Rik (arneson drives) (https://www.offshoreonly.com/forums/drives-lower-units/218288-question-rik-arneson-drives.html)
justdreamin 10-09-2009 02:46 AM
1 Attachment(s)
This picture is from your website... Am I looking at this right? It looks like a plate was used to seal up the transom where the lower units used to be and then surface drives were bolted to the plate. Is this a good idea? Does it work? And if so was a plate used on the inside too ?
Rik 10-09-2009 11:19 AM
That boat had BMAX drives on it with Yanmar 440's and they could not make it out of the Harbor :(
They (US Navy) just plated over the cutout and that's what you see. You do not need anything on the inside as the plate is 1/2" thick aluminum. Just seal it up and go again for the diesels. Gas engines, the Conversion kit removes the need for this.
