Bravo 1 problem..I think
Went on a weekend run (Destin to Orange Beach) got back and was flushing the boat with hatch up and heard a knocking, very consistent, three knocks then quiet...three knocks then quiet... I am pretty positive it is not the engine but the drive. Is it the bearing, U-joints, teeth missing?? How hard is this to tackle "Do it yourself"? Cost?
Thanks for the help. Ok Walked outside after reading some post and turned the prop. Turns free, no problem no knocking. While the engine is running and not in gear it is knocking in the very back and I am almost positive it's something with the drive....Suggestions? |
pull the drive off and check the U joint
New to all this, but if I can spin the prop fine does that narrow it down to the U-joint? What else should I look for when I pull the drive? Just trying to be prepared to inspect it all and know what to look for when I get it off. Thanks for the info on the U-joint.
Was the drive trimmed all the way up???? It needs to be down to prevent U joints from binding.
Also, it could just be the internal exhaust flappers. |
Pull the upper magnet, if you find metal flakes or chunks, then look inside. If not, then it might be ujoints, but not likely. I say missing teeth on the gears. The most likely cause for knocking. :(
If you want to look inside, drain some oil down and pull the back and then the top cap. You should be able to see the gear teeth and any damage by then. If you find metal on the magnet (not just fuzz) then pull the back cap. IF no metal then pull the drive and rotate the input shaft and inspect the ujoints. Hope this helps. Dick |
Originally Posted by Griff
(Post 2973295)
Originally Posted by Mr Gadgets
(Post 2973299)
If you want to look inside, drain some oil down and pull the back and then the top cap. You should be able to see the gear teeth and any damage by then. If you find metal on the magnet (not just fuzz) then pull the back cap. IF no metal then pull the drive and rotate the input shaft and inspect the ujoints. Hope this helps. Dick As for it's the exhaust flapper, I have heard that before and this is totally different sound, but I will do the easy check on that just to be sure. I just Love fall, summer is over and you find out what needs to be repaced before next summer. |
You need to put the drive in gear, with the engine OFF spin the prop back and forth. If you feel slop than it's the u-joints. The input shaft doesn't spin unless the motor is spinning.
I did not think about doing that before pulling the drive, thanks for the idea.
pulled the top cap on the drive, and had metal shavings. Who can tell me how much this is going to cost? Would I be better off trying to find a completely refurbed one?
Thanks for the help. If anyone knows a good Drive guy around my area let me know. Located 1hr North of Panama City Beach and 2 hrs from Destin. |
Kwooley,
what year is the drive and how many hours on it. Depending on how much damage is done inside, and the condition of the drive before the damage, will determine if it is better to rebuild or replace.. |
It's a 98 with 380 hrs on it, as far a I know. I have only had the boat for 2.5 months and they guy told me it was original. Oil has been changed and all the MNT. things.
Assuming the serial number begins with OL.. that would make it the old gears.. Best bet is a X gear kit upgrade. If the case is in good shape, inside and out, then it would be a good canidate for a rebuild.
I have a blend of parts that I build a B1 one with. I install steel tower in the case and use the XR ribbed top cap that also has a steel tower in it. PM with your email address if you want an estimate. Dick |
| All times are GMT -5. The time now is 03:52 PM. |
