-   -   how far up can I trim a #4 on boxes???? (https://www.offshoreonly.com/forums/drives-lower-units/219194-how-far-up-can-i-trim-4-boxes.html)
302Sport 10-27-2009 05:18 PM
My boat does not really have much bow lift and I have to trim it to the moon to carry the bow.....how far out can I trim #4's on boxes without hurting the u-joints????
HotPursuit 10-29-2009 09:55 PM
Maybe you should try spacers .. How straight is your drive shaft to begin with. Usely the joints will start letting you now when they dont like the angle. I would still try to correct the prop shaft height and work with B Blades for a good set up-- 4 blade with a different rake. If your trimming that high somethings wrong and your screwing up the design of a #4 on boxes. just my 2
notda1 11-06-2009 05:51 PM
I agree to start with raking first . The props can make a big difference on a surface drive .
