-   -   Speedo Hole Location (https://www.offshoreonly.com/forums/drives-lower-units/219531-speedo-hole-location.html)
nordic95 11-03-2009 07:13 PM
Hey guys I need to re-drill the speedo hole on the leading edge of my XR drives. I covered them with the nose cones I installed with intensions of using a GPS unit.Now times are tough and I need my speedo to work. Can someone give me a drill bit size for the hole? I also need a measurement down from top of lower or wing plate to hole location as well as depth of hole...Also can this include pictures of measuring so I know we are on the same page and I dont ruin a couple of drives...Thanks in advance for any help with this.
Thanks Anthony
Nordic95
Strip Poker 388 11-03-2009 07:30 PM
Thanks Anthony
Nordic95
Would the nose cone have apocket of air behind it.presure push on it from the inside??thats going to be hard to do.maybe some one has a blue print of one?
Rob
Boat Tech 11-03-2009 07:34 PM
Sorry at first this link was what I thought you where looking for But I guess not, Good luck.
http://forums.iboats.com/attachment....2&d=1253452752
http://forums.iboats.com/attachment....3&d=1244865292
nordic95 11-03-2009 07:40 PM
Rob
When I installed the cones I made sure there was no air between the cone and the drive. I took the cone and ground the inside to match the drive as close a possible.Then I mixed the epoxy and used a bar clamp to compress epoxy while tapping on housing and tightening clamp. Should be no air pocket, at least I hope. Is this speedo passage just a passage or does it open up into a pocket or cavity?
Anthony
Boat Tech 11-03-2009 08:01 PM
Anthony
A Cavity, If i was you I would drop the lower unit So you can look down the water passage main hole in the lower unit it's self, So you can see where the pick up hole is from the inside, You might need a light and a pick to find the hole, But it will be a lot safer to drill it out That way you will know for sure you do not drill pass the second wall, And leak oil in to the water cavity.
GLH 11-03-2009 08:14 PM
Get a handheld GPS for $99
RaggedEdge 11-04-2009 06:51 AM
Buy a transom mounted pick-up and hook it to the standard speedo hose that runs thru the transom assembly. When things change and you do go to the GPS unit you will only have a couple small screw holes to fill in.
hoozeyurdaddy 11-04-2009 08:54 AM
thats the way I would go, cheap, less chance of costing your self more money, and a whole lot easier.
Strip Poker 388 11-04-2009 10:19 AM
Thats a good idea:drink:
Rob
nordic95 11-04-2009 06:50 PM
Rob
Yea but thats to easy...I did look into the transome pick up but with a notched transom they mount them on the lower notch and then run hose thru bottom of boat,or top of notch so to say. I didnt want to add hole thru boat if I didnt have to.
Anthony
RaggedEdge 11-07-2009 05:28 PM
Anthony
That was the reason for the "hook it to the standard pick-up hose that runs thru the transom" comment. No more holes in the hull.
GO4BROKE 11-07-2009 07:38 PM
I second the GPS speedo.
Griff 11-08-2009 02:14 AM
I had a notched transom on the Pantera with a separate water speedo pick up. The speedo tube was drilled at least 6inches above the water line and the hose was just run longer. Tou definately don't want it going through the transom below the water line. Connect the pitot tube assembly to the tube that runs through the drive as said or for about the same $$$ as the pitot assembly, get a cheap handheld GPS.
