-   -   water in new bellows (https://www.offshoreonly.com/forums/drives-lower-units/220612-water-new-bellows.html)
ICDEDPPL 11-27-2009 09:55 PM
Pulled my drive off and this is what i found
http://img.photobucket.com/albums/v4...n/IMG00001.jpg
Its a brand new bellows/gimbal just put on a couple months ago, boat was in the water only a couple times after.
Bellows still looks brand new, I was able to turn the clamp at least 2 more turns maybe it was loose? not sure if where else the water could get in
2112 11-27-2009 10:07 PM
Unforutnately, you need to replace the Gimbal bearing and in my opinion the u-joints on your input shaft.
There could be a pin hole letting the water in thru the bellows or leaking past the drive-bellhousing interface.
The good news is you caught it before a catstrophic failure of the bearings mentioned above. It is a PITA but swap them out and for 20 bucks, put on another new bellows.
Yes, I have been there. Recently in fact. Start soaking your Gimbal bearing in PB corrosion buster now. Mine was a nightmare to get out.
At least it is winter now. :cool:
LAKESIDE RESTORATIONS 11-28-2009 10:30 AM
Unless you got way too much water in your bilge, I too would say it is time for a boot & bearing kit for the transom assembly.. :) Jamie / Lakeside
ICDEDPPL 11-28-2009 07:40 PM
I was afraid you guys might say that.. damn shame I only got two days out with this one.. turning the bearing by hand, its not exactly smooth :(
Who had best pricing on bearing kits? Is there a tool that makes accessing the bellow clamps easier?
thanx
found the tool .. flexible screwdriver Snap On tool Number 7M6A
LAKESIDE RESTORATIONS 11-28-2009 08:52 PM
We sell the kits. Feel free to give me a call on monday if you are interested.. :) Jamie / Lakeside Restorations 570-639-2628
marinetrans 11-28-2009 09:59 PM
Merc has a new gimbal bearing, non-geaseable, it has a "white dot" on it, it replaces the "red dot" one.They also have a "plug kit "to plug the zerk fitting pipe thread. ALL gimbal bearings will go to this now including Alpha which I think has a "yellow dot" and the Vazer has a "green dot".
ICDEDPPL 11-29-2009 09:30 AM
Lakeside: checked out your site, nice work you guys do...was wondering if you handle embroidery too... the logo is faded on my seats and hatch:
http://img.photobucket.com/albums/v4...derseat001.jpg
Not having any luck getting the old logo from AT, so is it possible to duplicate it?
I figure this would involve all new vinyl, probably would need to send you guys the whole seat?
thanx
LAKESIDE RESTORATIONS 11-29-2009 09:42 AM
thanx
Thanks. :)
We do, do upholstery work. If you want to give me a call this week I can go over what we could offer you.. :) Jamie / Lakeside 570-639-2628
Strip Poker 388 12-07-2009 12:31 AM
For the XR's ? is it supose to be better/stronger or just less maintance?
Havent heard of that one.
Rob:drink:
LAKESIDE RESTORATIONS 12-07-2009 06:55 AM
I belive less maint.. I personally dont like the idea of not being able to add a shot of grease periodically.. In a marine environment where stuff occassionally gets wet or damp to say the least, it is nice to be able to service some of the stuff to an extent.. Giving a couple shots of grease to the bearing here & there sure has the capability of keeping it in better shape long term.. I sort of wonder sometimes if they have a conspiracy & desire to sell more bearings & stuff..
