-   -   NXT water pickup issues (https://www.offshoreonly.com/forums/drives-lower-units/221330-nxt-water-pickup-issues.html)
fossil fuel 12-14-2009 06:55 PM
My NXT's find the only grass in 10 miles to plug up. The water pickups get clogged with swampgrass ! Merc says there is no issue. The intake plates are installed correctly. I think I will sharpen the edges so it will cut the grass ?? HELP
Uncle Dave 12-14-2009 08:25 PM
Curious.
Do you mean Kelp?
Do you have a sea strainer?
Uncle Dave
Jeff P31 12-15-2009 07:16 PM
I have the same problem with my Imco lowers . It is so bad for me that I'm going back to the stock lowers on my xr's and try that.
fossil fuel 12-16-2009 07:00 AM
I'm boating in the lower keys. Kelp is not an issue. Swamp grass is long and stringy. I do have strainers but the issue is plugging at the water intake under the lower case. The grass has to make two sharp turns at the intake plate to get into the drive. It hangs up at those angle points.
Uncle Dave 12-16-2009 09:32 AM
Got ya- I saw you were registered in solaa beach ca.
"No" swampgrass down there.
UD
fossil fuel 01-03-2010 07:14 PM
I removed the pickup plates. Merc already sharpens them somewhat. The side I was having the issues with had a rolled corner. I got out the trusty dremel tool and put the "edge" on them. I ran the boat a few hrs last week and no grass in the intakes....I think that solved the issue
