Max RPMs for bravo drive
What is the max rpms that you can push a bravo to? I'm not talking about flying out of the water at this level but with the prop staying in the water. Hp will be around 525-560.
Friend of mine used to race in P class... He would regularly see over 7Krpm on the tach. That was with a standard B1.. lived for 4-5 yrs before it didd..
I run an B1-XR to over 6300rpm.. If they are setup properly. they can be twisted. If the lash is too loose, the pinion trys to climb over the driven gear... |
