Extreme gimbal bearing removal... need help
I've beat myself silly with the slide hammer and have tightened my flat bar against the housing so tight that I'm concerned about breaking something else. The bearing isn't that old, doesn't show any signs of corrosion, and doesn't appear to be cocked sideways or anything. I've thought about drilling around the bearing. Never had one so tough that the flat bar method didn't get them. How tight can I go without breaking something? Any other ideas?
Not sure, but i think you may have to tilt the bearing and take it out sideways.
Originally Posted by offshorefisher
(Post 3069217)
Any other ideas?
I don't think you can knock the bearing sideways, and push it through the transom assembly - I don't think the hole is big enough, but I could be wrong. Tried applying heat/cold to it?? |
Read this starting at post number 23, You may need to sign up to see the photos.
http://forums.iboats.com/showthread.php?t=364003 |
Yeah, axle bearing puller works great.
Boat Tech.. that is a very good link you gave us. I ordered a set after I saw this.. I dont have a gimbal bearing to pull and I probably never will now!! Cheap insurance..
Thanks! Dick |
Looks like that transfers all the force to the gimble ring and the pivots. If it's really stuck, any chance of breaking the ring?
Seems a puller that uses a 'pipe-like' fixture that locates right around the outer lip of the bearings bore on th housing would keep the forces right at the bearing bore. |
Right.. pressure on pivots
My setup is very similiar. But, how much pressure can I add before I crack the ring?
Originally Posted by Mr Gadgets
(Post 3069618)
Thanks! Dick
(Post 3069837)
Is the bearing area all rusty? Does the bearing have/ Or get well greased over it's life? Or is it all dried up in there? If it's dried up you should start soaking it the best you can, And add some grease to the bearings zerk fitting as well, This may help you some. Good luck with it. Just another thought here is all, If you feel there is to much pressure on the bell housing, Maybe you could try to rig up some kind of strong handle to the end of the puller bar and use a "Come A Long" puller hooked to a tree or somthing like that. Just thinking out loud or outside the box is all.:drink: |
The easiest way to get the gimbal bearing out is to drill into the outside of the race. Drill one hole through the outside of the race and another 180 degrees opposite of the first hole, this will collapse the race and make it easy to pull, the race is soft aluminum. Center punch the race so the drill doesn't cut into the transom mount.
Gimbal bearings that were froze into place easily come out with this method. Forget the slide hammers and trying to use threaded rod. You're not going to re-use the bearing. Having the bearing install tool is a great investment, it saves time and will seat the bearing fully and properly. Been there done that. |
| All times are GMT -5. The time now is 11:38 AM. |
