-   -   Serial Number? (https://www.offshoreonly.com/forums/drives-lower-units/227291-serial-number.html)
Jim Diesel 03-28-2010 06:53 PM
Serial Number?
I have a bravo 1 upper that you cant read the serial number on, is the number stamped any were else?
Boat Tech 03-28-2010 07:43 PM
The serial number may be stamped in behind the sticker on the side of the drives upper unit.
Is the drive still the original drive that is mounted to the boat?
If so there might be a sticker on the engine someplace with the numbers.
This link may not be working today.:(
https://appcenter.mercurymarine.com/...Locator-mc.jsp
Jim Diesel 03-28-2010 10:51 PM
The drive is off a 03 25 outlaw that I had, it had broke two teeth on the forward gear and tore the pinion up. The case is good, looking to sell a good case just wanted to have the serial number for it!
Boat Tech 03-28-2010 11:37 PM
If you have the boats engine or/and transom assembly serial number lying around I might be able to look up the drive for you.
Jim Diesel 03-29-2010 12:14 PM
I do but I bought the boat as a repo, found out that the Bravo 1X drive was swapted for a Bravo 1 before I bought the boat! So when the B1 broke I replaced it with a B1X! So the serial number for the engine and transom assy still wont tell me anything, Thanks for helping. :drink:
customryder 03-29-2010 06:39 PM
some new drives have no #.. stamped anywhere....
just sell it..!!!:drink:
mike tkach 03-29-2010 06:54 PM
i baught 4 xr drives within the past year,2 new 2 merc remans,none of them have serial numbers.
Jim Diesel 03-30-2010 08:09 PM
Thanks :drink:
