-   -   lower bolts in a bravo 1 transome (https://www.offshoreonly.com/forums/drives-lower-units/227568-lower-bolts-bravo-1-transome.html)
ken3765 04-01-2010 06:24 PM
I am wondering if the lower bolts are susposed to be aluminum. That is what I found anyway and they are completely eroded away. I want to replace them with stainless bolts any input?
PAST DUE 04-01-2010 08:12 PM
its for corrosion i would not change them seeing where you live. they have anodes on the end of them.
ken3765 04-01-2010 08:52 PM
what I took off was nothing but a carriage bolt made of aluminum. Since reading your input Past Due I have found a set of zinc bolts with anode nuts. But from what you are saying if I am correct it is better to use aluminum in salt water?
PAST DUE 04-03-2010 07:38 PM
i am not sure about the zinc bolts but the ones you took out may be what you should put back in i could check on monday if you want to give me the serial # off the transom plate assy.
bajabob 04-04-2010 08:08 AM
they make both them bolts . some have them some dont . i have a formula and a baja. baja has the carrige bolt the fourmula has the better setup
