-   -   Speedometer water passage in lower (https://www.offshoreonly.com/forums/drives-lower-units/227689-speedometer-water-passage-lower.html)
firehawkcat 04-04-2010 01:56 PM
Is there a way to plug speedo water passage in lower without threading and screwing a plug in. If not using I know it needs to be plugged. What will happen if not plugged? Any help would be great
speedreeder 04-04-2010 08:17 PM
If you cut the hose on the outside of the lower unit, inside of the helmet, it will just blow out a little water and not hurt anything.
firehawkcat 04-04-2010 09:03 PM
I have a -2imco,drive spacer and a new teague xr just dont want to trash the shbang the first on the water
first time on the water that is
Griff 04-05-2010 01:58 AM
There should be a small hose on the leading edge of the drive just above the where the lower meets the upper, that could just be disconnected.
