-   -   looking for a part for a trs outdrive (https://www.offshoreonly.com/forums/drives-lower-units/229232-looking-part-trs-outdrive.html)
jslowss 04-27-2010 01:56 AM
im looking for the input shaft that goes from the out drive into the tranny. has a u joint on one end that goes into the yoke and then a splined shaft on the other end.. i dont know the proper name i guess and dont even know what to search ... anyone know what im looking for and a good website i could get one from? for a trs drive off a 86 chris craft 390 stinger thanks for any help!
c_deezy 04-27-2010 04:32 AM
http://www.mercruiserparts.com/Show_...+GEAR+ASSEMBLY
Part number 35 my man, depending on which transmission you have (Merctrans or Borg Warner).
Audiofn 04-27-2010 06:28 AM
Need to know what tranny you have to know what one you need. They are different depending on if it is a Merc Trans or a Borge Warner.
Jon
picklenjim 04-27-2010 10:22 AM
Borg-Warner has the splines on the outside of the shaft,externally. Merc Trans has the splines internally and a spring on the end. Here's another place where you can get them, a little cheaper.
http://www.perfprotech.com/store/ass...LY,986-50.aspx
Rookie 04-27-2010 04:03 PM
If you need a Borg Warner input shaft I might have one laying around in my garage.
MILD THUNDER 04-27-2010 05:01 PM
I might have one for a merc trans
MILD THUNDER 04-27-2010 05:09 PM
Just noticed its for a 390 chris craft stinger. More than likely its the borg warner setup
Rookie 04-27-2010 07:39 PM
Just checked, it is for a Merc trans. I had it removed from the new upper that I bought cause I needed the Borg Warner.
picklenjim 04-27-2010 10:12 PM
Ya a '86 would be a B-W if it's the original set up. One good thing the B-W shaft is 100 bucks cheaper than the Merc Trans one new.
redcorvetteman3 04-30-2010 08:35 PM
merc trans
I got two merc style if anyone needs them
Harvey 04-30-2010 09:53 PM
I have one if you still need it.
