Originally Posted by Quinlan
(Post 3109414)
Whole one would be nice 1.36.
As for what broke MY knowledge is still learning but the prop shaft broke in the back gear, the upper gears are pitted pretty badly and the shifting plate(?) w the knob on top snaped off. Bout 3K is what I REALLY understand! That's what broke on mine at the shootout ( propshaft inside of the gear) The pitted upper gears are a common thing on these:( Never had any problem with the shifting mechanisms. If you're on the same schedule as me, you'll be breaking a vertical shaft next:rolleyes: $ 1600 for a upper gearset, $750 for a propshaft, $ 3k sounds about right |
I broke a shaft inside the gear too & I did it at LOTO. Must be something in the water.
| All times are GMT -5. The time now is 04:22 PM. |
