-   -   Drive issue (https://www.offshoreonly.com/forums/drives-lower-units/230556-drive-issue.html)
DavidRaabe 05-16-2010 04:53 PM
Drive issue
Pair of Bravo 1's take very long to go down and one does not even go down all the way. When I hit the trailor button drives both come up real fast. Any thoughts on why so slow to go down? Plenty of fluid in both and pump seems to be functioning well.
KAAMA 05-16-2010 05:58 PM
have you had the drive off or the hydraulic lines/hoses disconnected lately???....the lines could actually be crossed. Just a thought
MDGperformance 05-16-2010 06:39 PM
Trim pistons probably going bad,you have high psi out of pump 1100-1200 psi in up,but in down only around 300-400,thats why up is working ,see that problem all the time time to rebuild or replace the pistons,you can spray wd40 in them and cycle them and get them to work for a while,need to get someone to stand on the drive while pressing the down button
nitroracer1 05-18-2010 04:37 PM
Damm too bad Kevin wasnt around to help you!!!
