Alpha I gen II resealed, but oil milky
I had milky oil in drive unit, so I changed seals under water pump and I tested drive unit with waterhose on drive unit in garage - 5 min and milky oil again ???
Is the plastic ring "old" under water pump ?
How the vacum test practically is made - if the drive is not holding vacum, how I know the problemic seal ?
Thank You !
Thank You !
