-   -   lose forward bravo i drive???? (https://www.offshoreonly.com/forums/drives-lower-units/231659-lose-forward-bravo-i-drive.html)
bajabob 05-31-2010 04:13 PM
got rev. no forward
Bajapred 06-03-2010 03:26 PM
There is a thrust washer under the cone gears in a standard bravo..when that thrust washer breaks you lose forward and usually not reverse...simple washer replacement should fix you up..but check your cone gear floor..sometimes a crack in the floor is what makes the washer break.
Driveguy 06-03-2010 05:37 PM
forward
The floor of the gear is broken buy a gearset and seal kits.
bajabob 06-03-2010 06:49 PM
yes inside the gear broke the gear is ok . is that wt you mean by floor of the gear
bajabob 06-03-2010 06:52 PM
thats wt happen got it fik . wt will make it stick in gear if the idle to high??
blue thunder 06-04-2010 03:39 PM
Yes, but also if the gears are not indexed in properly on install.
