-   -   TRS Rotation Question (https://www.offshoreonly.com/forums/drives-lower-units/232662-trs-rotation-question.html)
31scarab31 06-14-2010 03:08 PM
While looking from the input shaft side of the TRS unit, when I turn the input shaft clock wise the prop shaft spins the exact same way (looking from the input shat side). What rotation is this?
JaayTeee 06-14-2010 04:47 PM
The engines turn ccw ( viewed from the rear), so if both shafts are turning the same direction it's the l/h rotation drive.
Mbam 06-14-2010 04:54 PM
Exactly - also the end of the prop shaft should be stamped
MILD THUNDER 06-14-2010 07:23 PM
Yep, look for a little "R" or little "L" on the end of the propshaft. It will be stamped on the end. Kinda hard to see sometimes
31scarab31 06-14-2010 09:55 PM
thanks for the information.
