-   -   borg warner trans making noise rebuild or replace? (https://www.offshoreonly.com/forums/drives-lower-units/232862-borg-warner-trans-making-noise-rebuild-replace.html)
mookster 06-16-2010 05:26 PM
1984 borg warner trans with trs drives.. one trans in reverse sounds like it has marbles in it. if i had to rebuild both of them . im i better off replacing them with for say bravo 1 or not
amazing1 06-16-2010 07:44 PM
it only cost s 160.00 for the rebuild master kit. the bravos are going to cost alot more than that. the trannys are easy to rebuild yourself if you have some mechanical skills:evilb:
John the Drive Man 06-17-2010 07:11 AM
Have two rebuilds on the Shelf ready to go. Call; 954 237 0332
