-   -   NXT Drives (https://www.offshoreonly.com/forums/drives-lower-units/232866-nxt-drives.html)
Mad Props 06-16-2010 06:07 PM
NXT Drives
Does any one know if a 6 lower can be installed on a NXT? What does fountain do with theres?
A.O. Razor 06-16-2010 06:25 PM
I think they do #6 uppers and lowers on the NXT gimbal. Don't know about the #6 lower on the NTX upper.
Got Freedom? 08-02-2010 09:15 PM
A #6 drive will bolt to an NXT transom assembly but you need to change the input shaft on the drive to fit the NXT bearing carrier/transmission. I have one if you are interested.
You cannot just swap the lowers and the #6 drive does not have a water pickup built in.
