-   -   Side to side slop in a bravo 1 (https://www.offshoreonly.com/forums/drives-lower-units/233730-side-side-slop-bravo-1-a.html)
Fixxxer22 06-29-2010 10:53 PM
My buddy just picked a baja hammer really cheap. It has some issues the main problem is that the top of the gimbal ring is loose on that ( i was told the exact name) arm for the steering.... It looks as though the aluminum of the gimbal ring has been eaten away. what is the best fix? and he would be in the market for a used good ring. the only werid thing is that i looked at mine and our transom assys dont look the same mine is of 1993 build and his boat is a 1997. oh well. just need to fix it because it is unsafe
BY U BOY 06-29-2010 11:49 PM
he can send the ring to http://www.jrmarine.com/products/gimbal_repair.htm and have it repaired fairly cheap. Can also get the kit from them so you can get the ring off without pulling the engine.
I just did this job last year and got a new ring and helmet on ebay for 500.
doutlaw25 07-08-2010 03:27 PM
You can tighten the pinch bolt if it isn't to far gone. They make a plug kit so you can drill the transom plat to gain axcess to the bolts.
