Question for Rik @ Arneson, and others.
Ok.
Just got back from a lunch in the marina. Nice weather on a day off. We got into a pretty heated debate about suface drives. The question regards the ASD 6 bravo conversion. A guy at the marina has a Cobalt 302, with BIII's. Port side drive has just failed. The topic of our debate was, if an ASD 6 would be an alternative to the BIII and Volvo drives on these twin engined sport boats, such as the Formula 310ss/br 350ss, the mentioned Cobalt and the like? One thing everybody agreed upon was that, it is a more expensive alternative to the BIII. What are the pro's and con's in terms of performance, efficiency and durablility on this kind of boat, with 300 hp's to 425's? |
Originally Posted by A.O. Razor
(Post 3158227)
Ok.
Just got back from a lunch in the marina. Nice weather on a day off. We got into a pretty heated debate about suface drives. The question regards the ASD 6 bravo conversion. A guy at the marina has a Cobalt 302, with BIII's. Port side drive has just failed. The topic of our debate was, if an ASD 6 would be an alternative to the BIII and Volvo drives on these twin engined sport boats, such as the Formula 310ss/br 350ss, the mentioned Cobalt and the like? One thing everybody agreed upon was that, it is a more expensive alternative to the BIII. What are the pro's and con's in terms of performance, efficiency and durablility on this kind of boat, with 300 hp's to 425's? I ended up with a Formula 400ss instead and I have dreams of a pair of Youngs Performance style EFI 540's with ASD6 Bravo conversions but it's just a dream right now :) |
I would think so too. I don't know much about the Donzi, but one of the things talked about, was that the "small boats" such as the Sun Sport Formula's and others aren't stepped bottom performance hull's, where as the 40SS and Donzi are more performance oriented in thier bottom design. One of the big topics in our debate or rather argument, was wether or not the time to plane and midrange would suffer a great deal. If you could still get the 4-5 sec. time to plane, and a good midrange efficiency, that you kind of need on a boat like that, combined with the great durability, and possibly better top end of the Arnesons, that would be a dream setup for shure. And don't forget the rooster!:coolcowboy:
(Post 3158227)
Ok.
Just got back from a lunch in the marina. Nice weather on a day off. We got into a pretty heated debate about suface drives. The question regards the ASD 6 bravo conversion. A guy at the marina has a Cobalt 302, with BIII's. Port side drive has just failed. The topic of our debate was, if an ASD 6 would be an alternative to the BIII and Volvo drives on these twin engined sport boats, such as the Formula 310ss/br 350ss, the mentioned Cobalt and the like? One thing everybody agreed upon was that, it is a more expensive alternative to the BIII. What are the pro's and con's in terms of performance, efficiency and durablility on this kind of boat, with 300 hp's to 425's? One thing I am very certain about is the increase in speed as all the BIII's we replaced have increase speed significantly. The same boat with Arnesons will handle better, around the docks as well as slow speed and rough water conditions. The acceleration will also improve with the Arnesons. Con's if it can be said would be up front propeller cost but at the same time purchasing four propellers for a twin BIII setup is not cheap in the slightest, especially when only Merc (or even Volvo) makes those propellers. Mid range cruise speeds will rise along with top end with the Arnesons over the BIII's or Volvo Duo's |
Sounds pretty interesting Rik.
If you take my buddy's Cobalt 302 as an example. It runs about 51-52+ with the 6.2's. Not shure about prop's, but my guess is 26" Do you have an idea about top end improvement? What about time to plane? And the big question. Are they more corrosion resistant than the BIII's? I will take this info to the marina this weekend. A new custumer could be in the near future. There are quite a few boats where I am with BIII issues - corrosion, drive failure, ect. Thank you Rik |
(Post 3159543)
If you take my buddy's Cobalt 302 as an example. It runs about 51-52+ with the 6.2's. Not shure about prop's, but my guess is 26" Do you have an idea about top end improvement? What about time to plane? And the big question. Are they more corrosion resistant than the BIII's? I will take this info to the marina this weekend. A new custumer could be in the near future. There are quite a few boats where I am with BIII issues - corrosion, drive failure, ect. Thank you Rik Speed, midrange will close to 10 mph and top end 5-10+ depending upon the boat. |
Originally Posted by Rik
(Post 3159568)
You won't have corrosion issues with the Arnesons, especially if the boat is bonded correctly. Getting on plane will not be a problem as on those heavy boats we can run more diameter than the BIII's and more blades which will help getting out of the hole.
Speed, midrange will close to 10 mph and top end 5-10+ depending upon the boat. What type of regular maintenance is required for the Arneson's? Any hidden costs like a $3k flux capacitor that has to be replaced every two years as a "regular maintenance" item? :) I wonder what a pair of take off Bravo III's and related parts are worth anyway? Thanks, Pat |
In not so many words, yes. Every boat is different but the mid range has consistantly been about 10 mph faster than the Bravo's and this is 80% of your boating time so this is why I stress this to people.
No flux capacitors though. Just change the oil seasonally, monitor the zinc anodes, and run the crap out of it. |
Don't forget, the cost of the Arneson includes hydraulic steering!
Definitely a nice upgrade. Jeff |
(Post 3159846)
No flux capacitors though. Just change the oil seasonally, monitor the zinc anodes, and run the crap out of it. Another question............are there any modifications required when installing the conversion that would make it difficult to put the Bravo III's back on later? The thinking is if I did the conversion and kept the Bravo stuff, then decided to sell the boat later, could I easily reinstall the Bravo parts so I could keep the Arnesons for the next boat? Thanks again, Pat |
| All times are GMT -5. The time now is 10:27 PM. |
