-   -   bravo one gear unit (https://www.offshoreonly.com/forums/drives-lower-units/235393-bravo-one-gear-unit.html)
dizzie1 07-23-2010 05:25 PM
bravo one gear unit
I have a '97 Baja 272 502ci engine running a Bravo One outdrive. Recently a friend pulled back on the gear shift instead of the throttle and I think he may have chipped a gear tooth. The boat has a *slight* vibration when the motor is trimmed all the way down but it is hardly noticeable when the drive is trimmed up. I dont hear any clunking noises. Any ideas as to what the problem might be? Im hoping not the gear set, as it looks like thats about $1500+labor...
firehawkcat 07-23-2010 08:01 PM
check the magnet on drain plug and see if it has chunks of metal
Philster 07-25-2010 05:38 PM
Could be a number of things. Trim doesn't affect gears.... but gimbles and coupler more likely.
I just go the bad news for my 502/Bravo One. I did bust some gears in the upper. 1500 plus labor. Ouch.
