-   -   XZ to SSM III-A (https://www.offshoreonly.com/forums/drives-lower-units/237667-xz-ssm-iii.html)
RMPRam 08-26-2010 01:45 PM
Originally Posted by fireboatpilot (Post 3192218)
Hey Gary, Why don't yoou try to improve on the XR gears which Merc can't seem to do? I bet there would be a hugh market for a better gear set.
I will look into it. Possibly make a near net forged straight cut upper gear, just as Mercury did on the later #5's and the #3A's.
ICDEDPPL 08-26-2010 05:56 PM
X2!
Philm 08-26-2010 07:21 PM
Originally Posted by mastercraft240 (Post 3191388)
Damn you.:lolhit:
What did I say??? :kiss:
It was a reasonable question....:party-smiley-004:
Seriously though, SCX is the ticket. Gimble ring and helmet change required. Upper with these parts is going to be anywhere from $9k to $10k depending on what kind of deal you can get. You can get a used SC lower for less than $3k if you look around. Then you dont need to worry about setup, because it really wont change from what you have now. Except it will be indestructible.
