-   -   Bravo rotation? (https://www.offshoreonly.com/forums/drives-lower-units/238186-bravo-rotation.html)
MOP 09-01-2010 08:21 PM
Bravo rotation?
What is involved in changing the rotation of a Bravo?
DareDevil 09-01-2010 08:22 PM
nothing, u just hook it up in reverse !!!!!
BIGMC69 09-01-2010 08:38 PM
as far as i know you can run it either forward or reverse. if your running a right hand prop change to le hand prop and move shifter to reverse to try. If it works change your linkage on the shifter itself.
picklenjim 09-01-2010 09:50 PM
Cable change at the helm.
tomas_wallin 09-05-2010 05:03 AM
And use a very good drive shower!
mike tkach 09-05-2010 09:52 AM
CORRECT:coolcowboy:
