-   -   Stelling Ext Box Driveline Maintenance Interval? (https://www.offshoreonly.com/forums/drives-lower-units/239067-stelling-ext-box-driveline-maintenance-interval.html)
mr weazelle 09-14-2010 11:30 AM
What is the recommended timeframe for greasing the u-joints and the carrier bearing in the box? How long do the u-joints normally last before needing replacement? Has anyone had a catastrophic failure for the driveline and what happened?
Just trying to get some history of the longevity of these units.
Thanks,
Kevin
Griff 09-15-2010 01:57 AM
If you grease them, the Ujoints should last a very long time. I bought my boat used, but I think all the U joints and carrier bearing are original(1997). I grease all the zerts in mine at every oil change which is about every 30-40 hrs.
BenPerfected 09-17-2010 11:36 AM
As a precaution, we used to replace the u-joints every other year when we were racing. Depended on the angle of your set-up, it seems to me that you could run until you feel any vibration. I do not think there is any easy way to check the condition of the u-joints or the carrier bearing without full disassembly. If you have the engines out, I would definitely do a full inspection.
Ben
Baja_man 10-14-2010 11:32 AM
And keep them completly dry. Only failure I have heard of was at 130 Hrs. I believe.
