-   -   drive conversion: OMC to Bravo (https://www.offshoreonly.com/forums/drives-lower-units/240190-drive-conversion-omc-bravo.html)
SCARAB4me 10-04-2010 01:45 AM
Is this pretty doable, or is it a major head ache?
I am looking at a boat hull, and it used to be a 330hp 454 omc, all gone now. So could I drop a 454BBC in it, and a Bravo drive, or maybe even a 502?
Thanks for any input.
I would also consider an outboard if it is easier, and can find one or some to match the power or more than the 330hp 454.
Biggus 10-04-2010 06:05 AM
I've done the swap. The OMC Cobra series has the same transom cut out as the Bravo. The Merc drive was a bolt-on. I did have to move the motor mounts. Also, you need to install a Merc style throttle/shift control, the OMC operates backwards of the Merc.
Kurt
SCARAB4me 10-04-2010 12:36 PM
Excellent thanks for the info
I just noticed it had a omc/gimball, so would that still convert right over?
Fast Shafts 10-04-2010 12:57 PM
I also converted from an OMC King Cobra to a Bravo I. The bolt pattern is exactly the same for the transom assembly. EZ swap!
