-   -   Max safe rpm for bravo one? (https://www.offshoreonly.com/forums/drives-lower-units/240743-max-safe-rpm-bravo-one.html)
grjdc1 10-13-2010 05:23 PM
I am finishing up a forged 489 stroked 454 in my single engine baja and wanted to see if i could safely rev it to 5800 without hurting my bravo 1??
Tinkerer 10-13-2010 08:04 PM
I used to run mine at 6000 RPM till I changed to the current 28 pitch B1's
26awesome 10-13-2010 08:10 PM
I ran mine to 6500 RPM on saturday!
grjdc1 10-13-2010 09:02 PM
Figured it wasnt a problem, but a few local guys said id blow the drive.
waconda 10-13-2010 09:24 PM
Its only a matter of time.
fireboatpilot 10-13-2010 09:37 PM
It's not the rpm's that will kill it but the torque pu to it. Go easy on the hole shots and acceleration bursts and it could last for awhile. Start hammering it and it's a goner for sure.
Griff 10-14-2010 01:32 AM
More rpms= more heat= more chance of failures
I would say 6000rpms max with lube changes every 20 hrs
paul buckner 10-14-2010 03:06 AM
hi fireboat pilot paul here from england are you still selling drives you never got back to me with price regards paul
ElimiNordic 10-14-2010 05:14 AM
I have one that I run at 5800 to 5900 rpm for short periods of time with a nitrous blast and it has been fine for years. I do have back up drives reading and waiting to go.
Mr Gadgets 10-14-2010 05:53 AM
I used to run my 25' Checkmate to 6300 on a regular basis. But that was not a 5-10mile run. More for the river speed runs. Used to be the pinion gear would walk over the driven gear, but that was before people properly lashed the upper gear set. I used to build the B1 on the Caster's boat, National Champ, he would race it very hard.. see 7000rpm on the telltale.
You are better off running a higher rpm with less load and deal with the cooling than lug the motor down with a big prop and load the drive. just my .02.
Dick
Back4More 10-14-2010 04:25 PM
5 blades will kill a Bravo in a hurry.
goebel1 10-15-2010 09:57 AM
I run a 5 blade with a single 1000HP @ 5800 this year and have not killed mine yet.
Back4More 10-15-2010 04:50 PM
Your lake looks pretty flat...and as for your drive living, you know very well when and when not to apply the throttle.
Every 5 blade that got bolted up to a Bravo up here on Lake Michigan...RIP.
crayolacrazy 10-15-2010 06:21 PM
5800 rpm,s30 and 31 P5x two years xz,s imco lowers 8000 lb boat mostly on lake Erie Just keep it in the water ,and I cruise above my peak tourque witch is 3300 rpms
