-   -   Bravo One gears (https://www.offshoreonly.com/forums/drives-lower-units/240872-bravo-one-gears.html)
dykstra 10-16-2010 06:22 AM
Bravo One gears
Will the gears out of a newer(2008) Bravo One fit in an older Bravo one(1999) case?
dykstra 10-16-2010 06:24 AM
I know the newer case has the "swept back" upper and was wondering if that made a difference with gears.
Mr Gadgets 10-16-2010 06:20 PM
You need to change the races on the towers and used the thrust bearings and proper shims and cone clutch for them to fit.
