-   -   TR vs TRS (https://www.offshoreonly.com/forums/drives-lower-units/241538-tr-vs-trs.html)
wjb21ndtown 10-27-2010 04:33 PM
TR vs TRS
Does anyone know how to tell the difference between a TR and TRS by looking at the outside of the casing? I'm looking into buying a spare drive and the guy doesn't know for sure which model it is.
JaayTeee 10-27-2010 04:38 PM
A TR is a longer length lower leg than a TRS
( they can run up to a 20" diameter prop)
Houseboats/work boats used them
It's like comparing a bravo 2 ( TR) to a bravo 1 ( TRS)
wjb21ndtown 10-27-2010 06:58 PM
I know about the depth and prop thing, but is there a way to check bolt holes or something? I'm trying to tell the difference by looking at pics, and it's kind of tough.
picklenjim 10-27-2010 10:44 PM
The TR is 2:1 gear ratio and the TRS is 1.5:1. If the drive is off you can tell him to see how many times the input shaft has to turn to make the prop shaft turn one revolution. If you turn the input shaft 2 turns and the prop shaft only turns 1 revolution then it is a TR. If he turns the input shaft 1 1/2 turns to make the prop shaft turn 1 revolution then it's a TRS.
[email protected] 10-28-2010 11:24 PM
the lower unit on a tr is much bigger than trs, the top of the housing is the same
merlin 10-29-2010 07:18 AM
Trs
The TRS has a 1" propshaft.
rufusgrouse 11-16-2010 12:36 PM
The tr has a 1 1/4" propshaft
