bravo 1 questions
Should bravo 1 drives be removed yearly for general maintanance? If so, what service should be performed? Also, if running twins i was advised to swap drive positions annually creating opposite rotation so rotating parts wear evenly. Sounds logical but is this true? Will the life of the drive be extended that much? Advice, opinions, much appreciated. Thanks in advance.
I try to pull mine off annually and just have a look around. Make sure there isn't any water or drive lube leaking into the Drive Shaft Bellows, have a feel of the gimble bearing to make sure it is still butter smooth.
The Shift and Drive shaft bellows are maintenance items and should be replaced. I believe Mercruiser calls for 5-7 years on these items so have a look over them for cracks developing, etc...... There are two schools of through on the drive swap routine: I do NOT switch mine - I feel like once they are worn in a certain way that switching them only provides the possibility of wearing metal shavings off from the other rotation. I have had pretty good success with this method, but I drive like a *****..... |
Originally Posted by seafordguy
(Post 3247582)
engine alignment
When you have the drive off do you do the engine alignment check? Ever done this? how much trouble is it? how tight the engine mount bolts? bayonet fitting for drive oil supply any issues with this? What sort of wear issue is there with the coupling? Thanks
| All times are GMT -5. The time now is 01:11 PM. |
